New-ish owner. Mark V 35 Tube explanation.
Discussion for the new Mark V
hudakhan
Post by hudakhan » Mon Feb 11, 2019 3:55 pm
Fellas. First post. I've been lurking this forum for a few years, drooling over owning a Mark V someday. I got a new Mark V 35 combo about 8 months ago from the local music shop and could not have been happier. Gotta love 12 months, no interest financing. I love just looking at this thing, let alone hear it scream.
I have a bit of noise / hum in channel 2. Volume can be turned off on the guitar and amp, but I hear a hum / hiss noise. I want to troubleshoot the tubes. I've already had to replace a preamp tube. Need some help deciphering the tube diagram in the owner's manual.
I'm assuming V1-V10 means valve 1-10, but I don't know what the V1A or V1B mean and the manual doesn't explain.
Any help would be appreciated.
mace
Re: New-ish owner. Mark V 35 Tube explanation.
Post by mace » Mon Feb 11, 2019 10:27 pm
V1A and V1B are both inside the V1 tube. In other words, each pre-amp tube (AX7) has two different 'paths'. So, a single tube can be used for two different things. For example, the A side can be used for a gain stage and the B side used for reverb return (or whatever).
So, if your channel 2 is having issues, trouble shoot any pre-amp tube which has any mention of having a channel 2 gain stage (either A or B path of the tube).
Rankings: #1 Mark V head, #1b TC50 combo, #3 Rectoverb 25 head
stephen sawall
Post by stephen sawall » Tue Feb 12, 2019 1:52 am
Pull one preamp tube at a time and replace with a good one...till you find the problem.
hudakhan
Post by hudakhan » Tue Feb 12, 2019 12:32 pm
That makes sense. That helps. Appreciate the advice. I'm gonna pick up a few tubes and see if I can get this fixed.
Jfriley
Post by Jfriley » Mon Feb 18, 2019 11:22 am
I have the same amp head, my set up is fairly noisy (saturation mod plus Tubescreamer in front) so I have the TC Electronics sentry in the chain. You can connect it so that the gate sits in front AND in the loop, and it does the trick very well.
