Mesa MkV 25 problem
Leobeggiato
Hello
The reverb at my MkV 25 w year 2015 stoped to work ,together the clean channel started to sound a little bit fuzzy.
I installed new tubes jjtesla and nothing changed.
Checked the reverb tank (ok)
 I send to best amp tech service in town (Cestari amp) , and they explain that just can fix with the schematic because the very compact desing. I looked for in Web but   not found. I sent a email to MB and can help if I send the amp to California , but I live in Brazil and its very tough.
please if anyone could help here or mail me
Thank you
Leo
Check that the reverb tank connecting cable is fully seated at both ends. Good luck
Hello
I just checked that. Its ok. I think the problem could be in the reverb switching parts. The MkV 25w uses 4n32 and J174 FET to Reverb way. Next step, I will test this components and track the signal in the reverb tube. With a schematic could be much easer. Lets try the hard way
thanks
