Lonestar Classic Head Total Loss of Sound
Classics and Specials
Hompie29
Post by Hompie29 » Fri Jan 19, 2018 3:18 pm
Hi. I'm new to the forum and have a problem. Any help would be really appreciated.
Last night at practice I plugged in and switched on. The amp was on the 2nd channel an it seemed to have more hum than normal but was sounding good when I played. I switched to channel 1 with the footswitch. No hum whatsoever and it was working perfectly. I switched back to channel 2 and no sound!! Switched back to ch1 and no sound and I mean zero sound not even the sound of the amp being on. Only the fan. Switched the amp off and on a couple of times. Unplugged the footswich flicked the channel switch the wattage switches and the silicon/tube rectifier switch. Nothing!! All I could get was with the footswitch back in was a slight ticking inside the chassis when on ch 2.
Set up again at home tonight for another look. Again nothing can't get the ticking sound now. I changed every pre amp valve 1 at a time then switched all the power valves for a new set. Nothing!!
Anyone got any suggestions?
Thanks
plan-x
Re: Lonestar Classic Head Total Loss of Sound
Post by plan-x » Sun Jan 28, 2018 4:46 pm
If you're sure you got good preamp tubes in at replacement...then move on to the power tubes. Probably should get it to an amp tech.
Recto-Verb 25 head
Lonestar Classic (LSC) 2x12
Plan-x
https://myspace.com/wichmanbrewster/music/songs
Hompie29
Post by Hompie29 » Tue Jan 30, 2018 2:28 pm
Hi. Thanks for reply. Yeah I replaced all the pre and power tubes. I’ve sent the amp back under warranty. I’ll let you all know the outcome.
It’s killing me not having my Lonestar
Hompie29
Post by Hompie29 » Thu Feb 08, 2018 1:36 pm
Well that's weird!! After the amp not working which was witnessed by me, my supplier and the distributor rep. It now is!! It was taken back to the distributor under warranty. The tech apparently took it out the chassis and plugged it in and it worked fine. It has supposedly been checked over with no fault found. It was put back in the housing and played for an hour with no problem.
So I've got it back and it sounds great however I've lost a bit of confidence in the amp. I was wanting the problem identified and sorted. Can't help thinking what will stop that happening again.
darkbluemurder
Post by darkbluemurder » Fri Feb 09, 2018 5:37 am
I hear you - it is the same feeling I had years ago with my Acoustic G 100 T that broke down after a gig triggering a 200$ repair bill - mucho dinero for a student, and I could not work on amps myself at that time. The only thing to regain confidence in the amp is to play the amp. If it works, it works. The only other thing that comes to mind is to check every connection before firing up the amp, especially if there is a speaker plugged in.
Cheers Stephan
Hompie29
Post by Hompie29 » Fri Feb 09, 2018 1:09 pm
Cheers for the sympathy and advice Stephan. Yeah I’ll do that and hopefully all will be good.
