Lonestar + Graphic EQ
Posted: Mon Jan 02, 2017 4:17 pm
by Zest
Hi, (First Post)
I don't actually own a Lonestar but hearing how people complain that the Ch. 2 is too bassy I wondered if that problem could be solved by adding the Boogie Graphic EQ Pedal in the FX Loop?
I have searched the internet and haven't found anyone with this idea.
Thanks
Re: Lonestar + Graphic EQ
Posted: Mon Jan 02, 2017 5:46 pm
by bluesyballer27
I have used my MXR 10 band EQ with Channel 2--both in the loop and in front of the amp, with great results. One of the bands (125 or 250--can't remember which right now) represents the muddy frequency that channel two brings too much of. Pull it down to taste, and the mud clears up, and you can get clarity and crunch. I also push the upper mids and highs just a smidge. This is all after dialing in a tone (for me, its JTMish/Plexi level gain, with the Thick setting--definitely going for Plexi type tones) that is medium gain with good touch sensitivity--somewhere between Angus and early Eddie.
Posted: Mon Jan 02, 2017 6:05 pm
by bluesyballer27
I should add that I'm using my LSC through an LSS 1x12 cab in this scenario--the 1x12 is brighter and more open, which helps with Channel 2.
Posted: Thu Jan 05, 2017 4:35 pm
by The Lo Lands
EQ might help sculpting your tone. I don't think channel 2 of the LSC is too bassy. Around 9-10 o'clock with medium gain settings it sounds very warm with plenty of definition. I sometimes use the Xotic RC boost to give it a tad more grit with the bass knob rolled back around 11 and the treble around 12.30 (12 o'clock is noon). Channel 2 of the LSC also likes fuzz face kind of pedals, channel 2 reminds me a bit of the Marshall low gain JTM plexi amps. Thats not a bad thing but not for everyone.
