Getting no reverb on LS 2-12 combo
Markofzeebop
The reverb on my LS 2-12 combo seems to have stopped working--both channels are dry even with knobs turned all the way up. I replaced the 12ax7 tube that supports the reverb but that did not solve the problem. I am able to successfully run a reverb pedal throught the effects loop; so the SEND/RECEIVE effects loop seems to be unaffected. Any suggestions for other things I could try before parking it at a shop for 4-6 weeks?
Thanks
Mark
On my LSS 1x12 combo it was a break in one of the two wires inside the reverb tank. It broke right where it was soldered to a tag. I was gigging the amp a lot so it was probably due to the spring unit bouncing around when it was being moved.
Joe
