EL84 Lonestar Classic question
gimme789
HI, I picked up a used Lonestar Classic a while ago. It came with 6L6 tubes installed.
I understand these can be switched over to EL84s. A few questions :
1) How many EL84s would I need to buy ?
2) What brand would you recommend ( JJ ? ) for best sound & reliability
3) What is the procedure? Unplug old, plug in new ? Flip a bias switch someplace ?
4) Your thoughts on 6L6 .vs. EL84 sound ? ( I know this is subjective ... - will the
EL84s produce a more Marshall like sound ? ) Your preference ?
I will look on-line for a manual and see of these answers lie within, but I appreciate
any info & advice anyone may be willing to share.
TIA
Tom
TIA
Tom
Hi Tom,
EL84's are not compatible in the LoneStar. Perhaps you mean EL34's? If so, and you're using MESA tubes - its simply a matter of installing them and setting the bias switch to the correct position. You will notice a slight difference from 6L6's - EL34's will have more mid-range without the big bottom of the 6L6 - they will break up earlier than a 6L6, with a different harmonic content to the top. It will NOT make the amp sound like a Marshall...tube type alone does not change the circuit design! Thanks!
thanks for the reply, yes i meant 34s, do you know how many i need to buy ? ty
