Hi Guys,
Previously only a lurker, now a new member.
Currently a bit confused over what will work best for me in terms of Speakers, ext cabs, and ohm's.
I had 2 Celestion V30's I took out from my LSS setup and now they are running in replacement of the
stock blackshadows of the LSC. Only concern is that I had 8ohm V30's for the LSS, now I am running them
parallel and into the 4ohm input of the LSC. (8 ohm input is empty)
It sounds good -- but I have a nice 26-3/4" Mesa Boogie 1x12 cab that I could put another V30 into.
Not sure if I should buy a V30 8ohm and plug it into the other 4ohm input in the back..... OR purchase
a V30 16ohm and plug it into the 8ohm input in the back.
I tried putting a blackshadow into the ext cab and I didn't like tone of the 2 types of speakers together.
If I was to throw more money away, I could see myself buying a Rectifier 2x12 with V30's in it (8ohm again)
then I will be using both 4ohm inputs in the back.
I've read on another site that when the 8ohms is not used, I'm not getting the best sound, but isn't that preference based?
I personally like the 2x12 V30's 8ohm I have in right now, but would like to get a EXT cab setup.
Please advise, sorry for such a long and boring first post. =)
