Solo stopped working on LSS
Posted: Fri Nov 28, 2014 5:42 pm
by J200george
Thought I was going nuts... Tried loop hard bypass, all sorts of trials like taking all effects and effects loop out.... Ended up the footswitch cable is open circuit somewhere, the channel select works but solo doesn't. Need to check the continuity. Just thought I'd share.
Re: Solo stopped working on LSS
Posted: Sat Jan 17, 2015 3:58 pm
by rfrakes
So did you check the cable to make sure it has continuity? Or is it in the box? You have 3 conductors in that cable, so it can switch 2 different things.
Also, there must be another 12AX7 cascade gain stage added when you kick in Solo, check your 12AX7s.
Posted: Tue Jan 20, 2015 7:43 pm
by tle4
I had a problem with the solo button not working. It turned out that the solder connection where the switch is soldered to the board in the foot pedal came loose. I took it apart and re-flowed the solder and beefed them up a little bit and it was all good again. I also replaced the right angle TRS with a Neutrik right angle TRS. It is much better quality and less prone to fail. I have not had a problem with the footpedal since.
Posted: Tue Feb 10, 2015 4:12 pm
by J200george
Definitely the cable. Strange cos it gets no movement. Swapped for another stereo lead I had available.
Posted: Tue Feb 10, 2015 4:51 pm
by Authorized Boogie
rfrakes wrote:So did you check the cable to make sure it has continuity? Or is it in the box? You have 3 conductors in that cable, so it can switch 2 different things.
There is no additional gain stage when the Solo function is activated...its simply 2 volume pots in series. It has absolutely nothing tube related. Thanks
Posted: Tue Feb 10, 2015 4:52 pm
J200george wrote:Definitely the cable. Strange cos it gets no movement. Swapped for another stereo lead I had available.
99% of the time, its simply the cable. Glad you got it sorted...thanks!
