Hello all, My first post here. After reading a good number of posts in which a good number of LSC owners express a bit of unhappiness usually with channel 2, I thought perhaps I can help a few of you out ? I've owned my LSC for 7 years now, and I'm still learning ! I have the long head on a custom rectofier standard slant cab, in the blue bronco silver tolex finish. I was one of those unhappy people who couldn't get channel 2 to sound right. Channel 1 was always very good, but I thought that channel 1 could also be better. I went with the "Favorable" ohm mismatch in my set up, This is when your cab is wired at 8 ohms, and you power it from the heads 4 ohm output jack. To my ears, the sound got much warmer and easy on the ears. Hope this helps someone out.
