LSS best tubes for max clean headroom
Classics and Specials
picnic
Post by picnic » Mon Sep 29, 2014 10:21 am
I played a gig yesterday and noticed the amp was breaking up sooner than previous outings. I played it this morning so there doesn't appear or sound like there are any issues.
I bought it used a year ago and tubes are what came with it. Amp probably could use a tube swap since I play it about 10 hours a week. Normally I don't change preamp tubes, never seemed to make much of a difference. Power tubes have usually been JJ's for me. I like max clean on the clean channel. Pedals for dirt, even though the drive channel offers up some great OD.
What do you guys recommend?
Lonestar Special
Fargen Epic
Peavey Classic 30
Fender DRRI and BJ
Guitars Tele AmDlx, Strat AmDlx, Epi Dot, Les Paul 1960 RI
dodger916
Re: LSS best tubes for max clean headroom
Post by dodger916 » Mon Sep 29, 2014 8:48 pm
I noticed the same thing at our last gig, and it got more noticeable as the gig progressed, but at home it sounded normal. Definitely power tubes.
I like JJs in my DC-3 as they are very durable in DCs, which are notorious for their hot bias. Just make sure you use a good vendor (Eurotubes, Doug's) and tell them which amp you have. You could also go with Mesa or Groove Tubes.
1966 Fender Pro Reverb
DC-3 head
Orange Dual Terror
plan-x
Post by plan-x » Mon Sep 29, 2014 8:59 pm
JJ's rock. I called Euro Tubes and told them I wanted high headroom for max clean, I told them what amp I have and they did the rest. They picked 6L6's for my LSC that spec'd out for what I specified. They did the trick alright. My amp was stupid loud and clean after that. The Mesa tubes never sounded right after those JJ's. The Mesa tubes just kind of sound flat, lackluster. I did the whole re-tube, power and pre amp. Then you'll really hear the difference.
Fillmore 25 head
Lonestar Classic (LSC) 2x12
Plan-x
https://myspace.com/wichmanbrewster/music/songs
rfrakes
Post by rfrakes » Thu Oct 30, 2014 3:50 pm
I found out the hard way, you need to use MB matched power tubes, other brands might let the amp go into runaway and blow fuses, burn wire and transformers.
Ron
Lakeabilene
Post by Lakeabilene » Wed Nov 26, 2014 4:45 pm
Change preamp tubes and you can get a lot of difference if the tubes are right. I don't change them all mostly just V1 and V2. I am using Bugle Boys Amperex ECC83 in V1 and V2 right now. Really nice cleans and warm tones. I also change to RCA 7025 and Mullard and GE for the 12AX7 preamp tubes. I have several amps that all use 12AX7 so I just move them around and it's like getting a new amp. I like the Tubeking guy on ebay, I have not gotten a bad tube on ebay yet.
Here is Tubeking's guide to the NOS guitar amp tubes.
http://www.ebay.com/gds/The-Tubekings-G ... 944/g.html
Authorized Boogie
Post by Authorized Boogie » Wed Nov 26, 2014 5:49 pm
rfrakes wrote:I found out the hard way, you need to use MB matched power tubes, other brands might let the amp go into runaway and blow fuses, burn wire and transformers.
Ron
Not exactly...keep in mind there were other 'factors' with your situation.
If you're not using Mesa tubes, be sure you get tubes that are correctly rated for the amp. For example, Groove Tubes - must be rated between a 4-6. Any reputable tube dealer should be able to send you tubes with the correct current draw for a Mesa amp.
