Gonna Blow This 50 Amp Fuse!
ellem52
NY
(thank you Mick & Keef)
So on of my never ever, ever used EL-34s blew last night. Lots of rattles, pops and general noise... clearly a tube. My initial thought is that I would swap the Yellow Jackets in the 10 and 50 watt positions because clearly I blew the 10 watt tube. I'm only ever in the 10 watt setting.
That didn't work.
It turned out to be one of the EL34s. I had another duet handy so this was no big deal.
However, how can one of those tubes be the one that blew? Any ideas?
http://imageshack.us/photo/my-images/713/i0bu.jpg/
All four tubes do some work even in the lower watt mode. The lower watt mode lifts the grounds on the cathodes on two tubes, I believe.
