LSS 15 & 5w mode problem
Classics and Specials
dc3c46
Post by dc3c46 » Sat Mar 17, 2012 8:58 pm
Hi guys!
Just picked up my Lonestar Special from repair.
Cathode resistor was replaced and power tubes were replaced.
Came home and now it works only on the 30watt setting.
15 and 5 are dead silent. I know I should have tested the amp before
I went home.
Now I am seriously ticked off! Can't the repair dude test the rig
in all configurations?!
Anyone got an idea what the problem now is?
Cheers,
C.J.
thom
Re: LSS 15 & 5w mode problem
Post by thom » Sun Mar 18, 2012 3:45 am
Yes, most likely the rectifier tube has failed. Seems to happen a lot. There is a mod (use the search function here) to help prevent this happening. The mod should have been applied to later models (serial numbers over 4000 I think). Having said all that my LSS is old, Sn <1000 does not have the mod and has never blown a rectifier tube. I recommend you source an NOS (new old stock) tube as they will be far more robust than a new production tube.
You should probably check that the rectifier tube is seated correctly before you do anything, maybe it just came loose in transit...
Tom
