Geeks only! Anybody around here know...
(1.) What exactly is happening to the circuit when you change the reverb switch between 'warm' and 'bright'? Is it filtering what goes to the reverb or the reverb itself? Etc.
(2.) What exactly is happening with the 'Thick' and 'Thicker' settings? I can tell it's pre-gain, and it sounds great for certain things, but what's it doing? Changing the frequency of Ch 2's Treble control? And if so, to what 2 frequencies?
(3.) Why does the Boost add a layer of (quite nice) upper-end grit to the sound? It makes some people leave it on all the time. Probably just more power tube breakup.
(4.) Why does the Drive section brighten up the sound as well as adding gain? Is it the different tube type? I have mixed feelings about it... leans a bit bright for single coils etc. Wonder why it isn't voiced as an extension of Ch 2's gain control.
