LSS Loop - ok to engage with no efx? (tube problem)
Classics and Specials
BobL
Re: LSS Loop - ok to engage with no efx? (tube problem)
Post by BobL » Tue Dec 23, 2008 6:23 pm
I've had this issue rear it's ugly head on both of my Lonestars. On one it was the tube, now replaced with GT ECC83s, and the other was with the loop jacks. The loop is an easy fix using contact cleaner. Spray a 1/4" plug and the jack then run the plug in and out a few times. Do this for each jack. If it happens on stage, take an effects pedal cable and jumper from the in to the out jack with it. Either way the problem is solved. And keep dirty cables out of those jacks!! :D
1960 LP Historic, 1958 LP Historic, 1995 ES-335, 19xx ES-335 w/ Bigsby and custom plaque, 19xx ES-355, 19xx SG Standard, Custom Shop Strat, Custom Shop Tele
Lonestar 2ea., Vibrolux, Vibroverb, 66 Super Reverb, 73 Super Reverb, 66 Deluxe Reverb
thirstypirate
Post by thirstypirate » Wed Dec 24, 2008 9:38 pm
plan-x wrote:When I recieved my tubes from eurotubes, Bob had instructions with the shipment on how to clean the sockets. Spray some contact cleaner on the tube pins and insert in and out of the socket a couple of times or so. I found that the contact cleaner spray evaporates quickly, so ya gotta move fast. How come this chinese tube thing thats been circulating around this forum forever, doesn't affect say, every Lonestar, or mine.
Mine has Russian tubes as well.
07 LSC 2x12 w/ Reeder Mod and 2x12 Recto cab
A440
Post by A440 » Sun Dec 28, 2008 6:32 pm
a quick update...
much thanks to Octa and everyone for their posts
I did the contact cleaner thing to the efx loop jacks, and tried a chinese tube I had around in V3. so far, so good. the problem has not recurred.
if it comes back, it's going to the shop for a check up
ps...I think it could be very helpful to sticky some of these known tech issues/repair memos
Happy Holidays to All!
Mike J.
Octavarius
Post by Octavarius » Mon Dec 29, 2008 7:22 am
Glad you've solved the problem! :D (for now, at least)
I'll also vote for making the memo into a sticky. Could help a lot.
