It is currently Tue Jun 19, 2018 3:57 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Fri Sep 30, 2016 3:03 am
Having read so much, although happy with CH2, got my tech to do the mod on my LSS.
Using both Gibsons, found it easier to get the OD I wanted but the big benefit for me was making it easier to dial in the tones on the amp.
As a user of both CH1, CH2 and CH2 with drive, I was finding it a tad tiresome dialling in the tone based on size of room as the increase/decrease in volume needed impacted the tone/drive, as I guess it would. Now I can use a base set up for each channel.
BTW, whilst at it, he modded the reverb out so that I can use a footswitch for both reverb and the drive setting - this is invaluable.....nice if it hadn't been a separate FS to the channel selector, but then again......nice touch. LOVE the LSS
Gibson Les Paul Standard (2007)
Gibson SG, 61 reissue (2001)
Gibson es 335 (1972)
Various acoustics
LSS
PostPosted: Fri Feb 16, 2018 6:14 am
To me, the most shocking experience was to see that the clean channel and the drive channel sound the same if the drive is disengaged and the Thick/Thicker/Normal switch is in the normal position.
And of course, it became hard to get a sound that I actually didn't like. I have no idea how this can be achieved by swapping two pots of the same value - more or less because I measured them before the mod and I got slightly different values. 999Kohms as opposed to 1002Kohms if I remember correctly. And I don't remember which is which because it was a long time ago. But I never looked back, it works fantastic. This is a good amp.
PostPosted: Tue Apr 17, 2018 4:25 pm
As djw put it:
Quote:
I suppose the point of this mod and the discussion is to get the amp's OD to a happy place without adding pedals or other outboard gear.
So really, for everybody who has done this mod, it's essentially no different from using an EQ pedal aside from the convenience of dialing in a truer Channel 1 clone without having to push an additional button... right?
I still may do it regardless (for fun and because I can't help myself, not out of necessity), but am curious if people who have done this mod agree or disagree with my assessment? There isn't exactly a plethora of high-quality A/B test videos available to go over, so I'm basing my opinion primarily on written reviews.
(for what it's worth, I love the drive channel, but do use an EQ on songs that require tighter high gain sounds)
