Lone Star Reeder Mod #1: Channel 2 Pot-Swap
Classics and Specials
djw
Post by djw » Mon Dec 01, 2008 6:58 pm
The purpose of this thread is to collaboratively summarize and illustrate the pertinent details of the now-infamous Reeder Mod, and will be updated as new or corrected info arises. Suggestions, questions and additional feedback welcome! The huge original thread includes both helpful information and circular debate as to the merits and theoretical viability of the mod itself. If you have not made this change to your Lone Star, or have nothing helpful to add, please keep comments positive or at least terribly funny. The merits have been debated into the ground already. It works! It kicks butt, in fact!
Charles Reeder's originating idea and thread, which currently contains 321 posts, is here:
LSC/LSS owners; are you happy with channel2? Want to fix it?
BASIC MOD DESCRIPTION: Switch the pots for Channel 2's Gain and Master controls.
EFFECT: Brightens and clarifies the Lone Star's Drive channel. Brings Channel 2 closer to being a true clone of Channel 1. The end result is a Drive channel that duplicates the chime and clear transparency of the Clean channel with Drive disengaged; and maintains this character along with the full cascading drive capability for higher gain tones when the Drive is engaged.
ADDITIONAL PLUSES: The mod is invisible, easily reversible, and requires no extra parts. Benefits all Lone Star models to date. Thick and Thicker modes seem to have more effect. Both lower and higher gain settings have been heard to improve.
SKILLS NEEDED: Basic soldering competency; ability to take great care while tinkering in close proximity to high-voltage capacitors.
YOU SHOULD TRY THE MOD IF: You feel your Lone Star's Drive channel lacks clarity and definition; Channel 2 sounds muffled, muddy, too dark, too mid-rangey or simply incongruous with Channel 1; or you wish you had the essential character of the clean tone as the basis for your lead/drive tone.
YOU SHOULD NOT DO THE MOD IF: You are perfectly happy with your Lone Star's fat, throaty drive channel as-is.
HOW THE MOD WORKS
There's been quite a lot of debate about this, and I invite the more electrically savvy folks to weigh in (I am not one of these). We do know that Mesa instructs in the DR manual that you can switch the Presence pot in one channel for the same part in another, and this will clone that channel (reference needed here), so the notion of cloning or nearly cloning a channel with a pot swap is sanctioned and advocated by Mesa.
I'll give this a try though. The differences between the two pots (Gain in Ch2 comes as part #591047 and Master is part #581739) is limited to their respective tapers. So in theory we should be able to account for where these tapers -- the values at certain points along their sweep -- line up between Ch1 and 2, and get the same sound, albeit with drastically different-looking settings for Gain and Master.
ja22y wrote:Both pots are 1M but the tapers are different. Pot 1 (ch1 gain) rate of change is less than pot 2( ch2 gain) between 8:00 (min) to 2:00; but its rate of change is more between 2:00 to 4:00 (max). So for the same visual setting, you get more gain on ch2 at low setting and ch1 'catches up' with ch 2 at high setting. Theoretically, if you mark the points where both pots have the same resistance ( master pots also) you should be able to dial-in the same tone. Also if you max either the master or gain pots, you would elliminate its affect and allow you to play around with one set of pot so you can hear the difference. Hope it makes sense.
While this is true in theory, practically speaking there still seems to be a hitch. It could be that the rate of change in the Gain control is not fine enough in places where those of us who haven't bonded with Ch2 stock want to set it; it could simply boil down to usability.
So swapping the pots appears to bring the two channels back into the same basic functional place, in terms of how the gain and masters play with the tone stack at usable settings. It doesn't seem like it would make such a huge difference... but it does, tremendously.
HOW TO DO THE MOD
SAFETY NOTE: If you are at all uncomfortable with electronics, soldering, or taking care around extremely hazardous electronic components, DO NOT DO THIS YOURSELF, HAVE A PRO DO IT FOR YOU. Please take the time to understand the safety requirements when opening and working with the insides of tube amps. Especially: Do not touch the blue cylindrical capacitors. Even when the amp is unplugged, they likely will contain enough static charge to cause you serious, deadly harm if touched and allowed to dump all that energy into you.
The instructions below assume:
- You understand the important safety precautions.
- You know about the LS' 5th screw, threaded up through the underside of the amp, which is for grounding and vibration dampening.
- You know how to remove the amp chassis from the cabinet, taking care to place it on a steady and well-lit work surface; and you have done this.
1. Use a small flathead screwdriver to loosen and remove the knobs and plastic washers from the Gain and Master controls of both channels. Loosen and remove the short hex nuts around the threaded collars in front of the Ch1 controls. The pots should now be sitting in their holes in the chassis, loosely.
2. Push the Gain and Master pots for Channel 1 back into the amp, still connected but out of the way. You need to do this in order to access the controls for Channel 2.
3. Look down at the Gain and Master pots for Ch2 as they sit in the chassis. Notice that they each have 3 wires, one connected to each terminal on the pot. In order to remember which wire is connected to which terminal, mark them with a sharpie: 1 dot for the leftmost, 2 dots for the center, and 3 dots for the right. Also, you may want to mark one or both pots so you can remember which is going where (or you can refer to the manual's component guide).
4. Unsolder the wires connected to the Ch2 Gain & Master pots, and push them back and up.
5. Loosen and remove the hex nuts from the pots. Pushing the pots straight into the amp in some cases will cause them to abut against the PC board; I had to tilt mine up and wiggle them a bit before I could get them out, there's not much room in there.
6. Switch the pots' positions, insert them into their new holes, and reattach the hex nuts. Do not over-tighten the hex nuts.
7. Re-solder the 1-2-3 connections on each of the pots.
8. Re-affix the Ch1 controls, reattach knobs, reassemble amp + cab, and don't forget your AC and speaker connections.
9. Enjoy.
TESTIMONY
Before
Many users have expressed dissatisfaction with the Lone Star's stock Drive channel. The complaints vary:
I have had difficulty in accepting the sound of ch 2. Upon switching from ch 1 to ch 2 the sound characteristics change dramatically and in a 3 piece band, it's noticable. The bottom falls out and the mids soar. I prefer a more smooth transition and so does the ears of the audience. It's more professional and less garage.
I couldn't get the bass to sound right on channel-2 either...if I turned it up 'everything' got 'mushy'...if I turned it down the sound was 'dead' or flat...and lacked 'punch'. The mids had too much prominence.
IMO the way ch 2 is set up from the factory is like a cheap tube screamer clone.
I like to set up ch 2 just a little hairier than ch 1 and only use the gain for this but there still seems to be some compression or something there that I don't like. As far as the drive/thick/thicker goes, there's nothing there for me.
Sound(s) very compressed and lifeless with one of those quilted moving company blankets over it...
After
The positive results have been described variously too:
Let me tell you; when you add the 'drive' and/or the 'thick/thicker' to channel-2 now it just takes off like a bird and sings! It actually gets more distortion and sustain (if you want it)...
...kick in the drive to about 11:00 with the gain at 1:00 and BAM! , Angus meets Eddie, Bitchin stuff. Then I pegged the drive and WOW! A silky, thick growl from a power chord sustaining with symetric smoothness. After that I backed off to a 10:00 drive and 1:00 gain with cloned EQ to obtain a really nice OD that straddles the line for a touch sensitive edgy-drive.
Everything just seems clearer. Glassier, woodier, more real and alive. And now I get that same addictive feeling from Channel 2 that I always got from Channel 1.
Getting results as described. Pretty much a ch 1 clone but when you add gain or drive, the compression or darkness isn't there. You still get all the 3D spank, sparkle and chime if you want it only with the amount of gain, grit, balls that you choose.
Holy S@#t!!!!!!! I did the Reeder Mod today and it's amazing how open and lush it makes channel two with the drive engaged. The distortion is very articulate.
The mod has changed the way the gain and drive stages interact with each other, and so all previous ideas about settings need to be scrapped and re-discovered, but now, instead of ch2 having a basic sound I was unhappy with and trying to find a solution, I am starting with a basic sound that I LOVE (ie ch1) and adding extra grit etc.
Some users have performed the mod and reversed it back to the original configuration, deciding that they liked the stock setup better.
A(n)... effect of this mod appears to be slightly thin sound with effects pedals that I currently use...
I lost the subtle grind that was so pleasant to listen to and found my self reaching for more and more gain to acheive the same effect. Unfortunately by the time I found the same feel in the guitar the tone was nowhere close to usable for me.
The other thing the mid-range does is give you a different overdrive sound when the drive is engaged and again I know some people think it's too midrangey but I personally think it sounds thicker and has more depth.
I reversed back and like the muddier edge to channel II un-modded
Warrantee
thirstypirate verified that the mod would not automatically invalidate the warrantee.
thirstypirate wrote: I just got finished talking with Chris at Mesa about the Reeder Mod and got some significant information for anyone, like myself, who was concerned about voiding the warranty as well as those who doubt the validity of the mod itself.
Firstly, he had never heard of the mod before and after I explained to him some of the details and tone characteristics that you guys have posted here he said that he needed to check out the part numbers of the pots. After doing so he agreed completely that switching those two pots would produce a true clone of Channel 1.
He then told me that doing the mod would not void the warranty as long as the soldering job was clean and no damage was incurred while doing it.
I took a few pictures while doing the mod; here are some of them, with some comments:
http://forum.grailtone.com/viewtopic.ph ... 09#p179109
Thanks to plan-x, thirstypirate, ja22y, BobL, Monsta-Tone, sbalderrama and all the other players who put so much thought and energy into this idea.
And a big thanks to Charles Reeder for his fearlessly innovative spirit!
EDIT: I just added an update/comment. As a member of the Owners of Both Lone Star Models Club I can attest to the finding, having just modded my LSS, that both the LSC and the LSS benefit equally from the Reeder mods.
LP Std Gold Top | LP Special | AmDlx Strat | AmStd Tele | SG Std 60s | ES335 | FSR Tele
Lone Star Classic
Lone Star Special
Electra Dyne
Mini Rec 25
TransAtlantic 15
Lone Star 27, 23 & 19, RA 27 1x12, WBCB 1x12 Cabs
http://www.damonwood.com
SonOfIAm
Re: Lone Star Reeder Mod #1: Channel 2 Pot-Swap
Post by SonOfIAm » Tue Mar 24, 2009 6:08 pm
I did the Reeder Mod yesterday, it was very easy to do and I am very pleased with the result! IMO it did not change the gain "structure" at all, seems like the same type of overdrive/distortion as before. It just brightened up the channel making it more useable for me with other pickup combinations. Before the mod, my Strat or Tele neck pickups were basically useless, they seemed to lose definition and character. Don't get me wrong, I liked the tone originally but it still lacked a little something. The mod has given me a more lively and useable distortion channel and it also responds well to my Barber LTD, thanks!
Mesa Roadster
Splawn Competition
Fractal Audio FX-8
Fender American Deluxe V-Neck Strat w/Kinman Blues
PRS CE-24 w/Dimarzios
Ibanez JS2400
djw
Post by djw » Wed Mar 25, 2009 1:18 pm
SonOfIAm wrote:I did the Reeder Mod yesterday, it was very easy to do and I am very pleased with the result! IMO it did not change the gain "structure" at all, seems like the same type of overdrive/distortion as before. It just brightened up the channel making it more useable for me with other pickup combinations. Before the mod, my Strat or Tele neck pickups were basically useless, they seemed to lose definition and character. Don't get me wrong, I liked the tone originally but it still lacked a little something. The mod has given me a more lively and useable distortion channel and it also responds well to my Barber LTD, thanks!
Congratulations, SonOfIAm. It's true, single coils really seem to benefit from this change; you get all the sparkle back, and the Thick & Thicker options really make a difference now. I go back and forth a lot between using LOTS of gain (drive and gain both at or above 2:00) and dialing it way back to medium or low gain. But I use way more gain now than I could ever imagine using before (hell, why not?). It's both fat AND detailed... it's totally usable and cleans up beautifully with your guitar controls.
A nice thing about the LTD is that you can set your amp for a pretty juicy medium gain and push it out to endless-sustainville with a moderate setting on the pedal, and it still sounds just like the amp: clear, responsive and dynamic.
Have fun!
Lone Star Classic
Lone Star Special
Electra Dyne
Mini Rec 25
TransAtlantic 15
SonOfIAm
Post by SonOfIAm » Wed Mar 25, 2009 2:12 pm
Thanks djw. I have the drive at 11:00 and the gain at 2:30 with the tone switch set to "thicker". I am finding by having the drive set lower, the distortion is more open to my ears. Adding the LTD really does make it sing! :D
Mesa Roadster
Splawn Competition
Fractal Audio FX-8
Ibanez JS2400
nicolasrivera
Post by nicolasrivera » Fri Jul 03, 2009 8:54 pm
Hello dear friends and thanks for this post.
As i could not find a sound sample of the MOD i took the task and record a simple sample with stereo separation, right has the NO MOD sound and the Left WITH the MOD.
I will say no more and left you to judge if you hear the difference or not.
http://www.youtube.com/watch?v=Ym3-nIuatFo
djw
Post by djw » Sat Jul 04, 2009 3:50 pm
Wow, very cool. I haven't had a chance to listen to the channels separately but this is the first time I've seen anything that did something like this -- nice work. Thanks for posting!
FYI, I did several clips of my amp with the mod -- nothing scientific with before and after samples, but some proofs that the mod makes the amp cut better (to my ears anyway). Here's a few samples:
http://www.youtube.com/watch?v=pZYWHjiPnME
http://www.youtube.com/watch?v=2F9gx-0u4-c
http://www.youtube.com/watch?v=-ca1gAZoQbY
Lone Star Classic
Lone Star Special
Electra Dyne
Mini Rec 25
TransAtlantic 15
Kiteboarder
Post by Kiteboarder » Sat Jul 04, 2009 11:03 pm
Hey guys, I just got an email that there had been a new post here. And... It just reminded me that you guys might be interested in listening to a whole song recorded with my Reeder Modded LSC.
All the clean parts were recorded with the LSC's clean channel. The overdrive parts were a combination of the LSC's Channel 2 & Channel 1 with a TS808 and sometimes and OCD. The heavier distortion parts near the end were done with an Egnater Rebel 20. The lead parts throughout were also the Rebel.
By the way, the speakers in the LSC are V30's. The guitar for the clean parts is an Ibanez JTK2 and for the clean and leads parts is an American Ash Strat HSS.
The song is SURF GREEN in the list of songs at the left. Let me know what you think, and if you like it, please become a fan. Finally, keep in mind this is a full recording with compression, effects and what not. It's not a scientific representation of the LSC Reeder Modded, but it'll show you one thing it can do really well. Enjoy! Here's the link...
http://www.facebook.com/sixstringsensei
-Danny
Band: http://www.myspace.com/rightisbackside
Solo: http://www.facebook.com/sixstringsensei
  • Egnater Rebel 20 - Tourmaster 2x12 Cab - Rebel 112x Cab
  • Mesa Boogie Lonestar Classic
  • Fender American Ash Stratocaster HSS
  • Ibanez Jet King II JTK2
djw
Post by djw » Mon Jul 06, 2009 11:48 am
Hey Danny, sounds great! Weirdly, I don't have a Facebook account yet... so I can "fan" ya. If I ever get around to it, I will though. Great work, as always. I'm guessing you played all the tracks, right? Right on, bro.
Lone Star Classic
Lone Star Special
Electra Dyne
Mini Rec 25
TransAtlantic 15
Kiteboarder
Post by Kiteboarder » Mon Jul 06, 2009 2:17 pm
djw wrote:Hey Danny, sounds great! Weirdly, I don't have a Facebook account yet... so I can "fan" ya. If I ever get around to it, I will though. Great work, as always. I'm guessing you played all the tracks, right? Right on, bro.
Hi Damon, I did play all the instruments :) Thanks for the comments. You should open a facebook account. You are going to love it.
-D
x6stringer
Post by x6stringer » Mon Aug 03, 2009 10:16 pm
Thought I'd weigh in on the Reeder Mod. I did the mod yesterday and after a day of playing with it, I'm SO glad I did. Actually, it didn't take a day to figure out it was a keeper. I play an American Tele with a stock pu in the bridge and the mini-strat pickup by Harmonic Design in the neck. I LOVE my tele, but I could never get it dialed in with the lonestar. This was very upsetting to me 'cuz it's my main axe and the one I like to play the most. Like others, I never got comfortable with the 2nd channel. Too thick, congested, muddy lower mids,etc. Escpecially with a tele. I could get away with it with my strat but it still wasn't a "great" tone to me. I basically wanted a Fender tone, but with ATTITUDE. I love the Lonestar and all of it's tone shaping ablilites, but never felt like I LOVED the amp. Somedays I'd get tones out of it I would love, but I always came back to trying to get the mud out. I switched tubes. I even switched the speakers to V30's. That helped, but that wasn't what I was looking for either. Those were just bandaids to try to take care of the core problem in the amp itself. So, what the Reeder mod did is exactly what I was looking for.... mud gone!! YES!!!! THANK YOU MR. REEDER!! There is MORE than enough drive available and now the amp breathes instead of choking. My BB and Sparkledrive both KILL with this amp now! Awesome.
Mesa Lonestar
Mesa TA-30
'65RI Fender Super Reverb
Fender Supersonic 22
Fender Blues Jr.
Marshall JCM800
Roland Cube 40XL
Fender American Tele, American Special Strat, '61 reissue Gibson SG, Gibson Les Paul Special and Les Paul Studio
fox5150
Post by fox5150 » Wed Aug 12, 2009 5:35 pm
Hi,
I've been following the Reeder mod posts for some time to gauge feedback and so on. I think the time has come to try this on my LoneStar Special. Before I take it to my tech (I'm fine with the soldering, just not around those voltages) it would be really good to hear from anybody who has tried this on the Special specifically, as most of the feedback seems to be from Classic owners.
Any comments would be great.
Thanks,
Simon
Mesa Boogie LoneStar Special
Gibson Les Paul 2002 Standard
Fender 50th Anniversary American Series Stratocaster
Fender '52 American Vintage Re-Issue Telecaster
Fender Deluxe Vintage Player ‘62 Stratocaster
PRS 513
Steve73
Post by Steve73 » Fri Sep 25, 2009 3:05 pm
Hi,
Just saw your post about the mods with the LSS. I have done both Reeder mods to my LSS and they have done nothing but good for the amp, specifically in Channel two. The second channel sounds less compressed now and the dirt is more useable now in a band situation. Before, in certain rooms, I would have trouble cutting through the band with the low mid emphasis of the stock Channel two.
jonanderson23
Post by jonanderson23 » Thu Dec 17, 2009 12:05 am
How does the Reeder Mod sound with humbuckers? I play a PRS DGT, which does have a coil tap, and a Gibson 339. I had a problem with the muddiness as well so I switched out the 6l6's for El34's. They cleaned it up a bit. Any thoughts?
Mesa Mark V head
Reinhardt 18 head
Reinhardt 2x12 slant cab
Mesa 2x12 slant cab
Gibson ES 339
PRS DGT
Fender American Strat
djw
Post by djw » Thu Dec 17, 2009 8:00 pm
jonanderson23 wrote:How does the Reeder Mod sound with humbuckers? I play a PRS DGT, which does have a coil tap, and a Gibson 339. I had a problem with the muddiness as well so I switched out the 6l6's for El34's. They cleaned it up a bit. Any thoughts?
Regarding humbuckers, I think it sounds great. Haven't heard anything that sounds bad, really.... PAFs, P90s, Strats, Teles... there hasn't been a guitar that I couldn't work with. I don't think the mod "thins" things out at all, though it does make things brighter. But I still hear a lot of girth and richness in the tone, it just has a cleaner edge.
EL34s are one way to deal with things, but that didn't do the trick -- for me, at least.
Lone Star Classic
Lone Star Special
Electra Dyne
Mini Rec 25
TransAtlantic 15
jonanderson23
Post by jonanderson23 » Thu Dec 17, 2009 10:45 pm
Thanks. I'd like to give the mod a try. I need to find someone that will do it. I know jack sh!t about doing it myself and I live in true rural america several hours from a tech. I've read about how to do the mod. I have a friend in the band who did some pickup install for me. Same level of expertise or do I need to find the tech? He's done some electronics work in the army.
Mesa Mark V head
Reinhardt 18 head
Mesa 2x12 slant cab
Gibson ES 339
PRS DGT
