Hi, everyone, I'm new here. I just got my first Mesa Boogie, an Express 5:50 (not plus). It's used. It has a weird behavior that I noticed while playing with it today.
If the footswitch is plugged in, I cannot use the toggle on the amp to switch to CH1. I can toggle to CH2, and I can use the footswitch to toggle back and forth between CH1 and CH2 when the toggle is in either the CH1 or FTSW position. But if the amp has been switched to CH2, I cannot use the amp's toggle to go back to CH1.
When the footswitch is not plugged in, then I can toggle to CH2, and toggling to either CH1 or FTSW puts me in CH1, as expected.
Do other 5:50s behave this (undocumented) way, or do you think my switch is broken?
I haven't found any other problems with the amp, except that the reverb tank and cables are missing.
CH1 cannot be toggled when footswitch is connected
Re: CH1 cannot be toggled when footswitch is connected
This is working correctly. The footswitch will over-ride the toggle.
2012 - Fender American Std Strat w/ lipstick pickups
2016 - Godin Passion Custom
2014 - Mark V - 90W Combo
2014 - Mini-rectifier 25 murdered out
2016 - Express 5:50+ Combo
2015 - 2x12 Recto cab w/V30s
2015 - 1x12 wide-body w/V30s and Wicker Grill
It doesn't seem right that the footswitch overrides the toggle when toggling to CH1 but it lets me toggle to CH2. Is that how your amp works?
- Authorized Boogie
- Mark IV
- Contact:
That is completely normal operation. Thanks
Okay, thanks for the reassurance!
