Easiest Way to Install Speaker in 5:25 plus Combo Amp
5:25 and 5:50's
Phaze11111
Post by Phaze11111 » Wed Aug 27, 2014 7:31 am
Hi all. I’m planning to change the speaker in my 5:25+ combo amp and have a question about doing so. I know I can change the speaker from the back by removing the amp chassis, reverb, etc. But what happens if I simply remove the four screws on the front speaker grill? Will the grill with speaker just come off as a unit for a very easy swap?
Thanks in advance for your advice, wisdom, tips and tricks! I sure love this amp.
FYI, I’m planning to install an Eminence EJ1250 speaker.
Mullenski
Re: Easiest Way to Install Speaker in 5:25 plus Combo Amp
Post by Mullenski » Wed Aug 27, 2014 6:32 pm
The four screws in the front are grill-only. Don't bother.
I was able to do a swap only removing the reverb tank. Pull the tubes, leave the chassis.
b00g13mk2B
Post by b00g13mk2B » Wed Aug 27, 2014 7:43 pm
I pulled the chassis and reverb unit. Was difficult getting the reverb unit back in with the covering tucked back neatly. Much easier on the Mark II with front mount speaker.
MKIIA in Custom Black Limba Cabinet Tone Tubby Winterland;
Express 5:25+ with Tone Tubby Purple Haze
Phaze11111
Post by Phaze11111 » Thu Aug 28, 2014 6:50 pm
Thanks for your responses. Looks like I'll be pulling the chassis and reverb unit for a speaker swap. Enjoy your MB amps!
