Loud "pop" switching between channels
surfinboy
I've got a 5:25 Express Plus and there's a loud popping sound switching between channels, even when everything's turned to zero (so it's not because of a volume or gain difference). It happens on both the switch on the amp and with the footswitch. Thoughts/suggestions?
Do you have engaged the EQ on both channels? Is it set on "Sliders" on one channel and "Preset" on the other?
The EQ is engaged on both channels, and set to the preset (not sliders). I'll see if turning the eq off affects it. The wattage is the same on both channels.
