External cab configuration for 5:25 Express combo
5:25 and 5:50's
gpuma
Post by gpuma » Mon Apr 28, 2014 11:21 am
Hi all,
I have a 5:25 Express combo (1x10) that I would like to connect to an external 1x12 16 Ohm cab.
The 5:25 has one 8 Ohm outlet (currently taken by the combo speaker) and two 4 Ohm outlets.
I'd like to have both speakers connected, possibly. What's the best way to do it?
Thanks a lot
SteveB
Re: External cab configuration for 5:25 Express combo
Post by SteveB » Tue Apr 29, 2014 4:51 pm
You should take a look at the owner's manual, which I think is available online. It contains a long list of safe wiring schemes. For example, it looks like a safe mismatch would be to plug the 8 ohm combo speaker into the 4 ohm jack and the 16 ohm extension cabinet speaker into the 8 ohm jack. You could also email Mesa to confirm.
gpuma
Post by gpuma » Wed Apr 30, 2014 9:00 am
Yes, I noticed. Thank you so much Steve for taking the time to answer my question.
Pardo
Post by Pardo » Fri May 02, 2014 7:24 am
This is an interesting idea. I'd love to use my 4x12 to drive my sound and use the combo with speaker engaged as a monitor for the drummer. I obviously couldn't point the combo directly at the drummer, but it'd give some flexibility.
I gave up on this idea because I was told it was unsafe years ago. I'll explore it again, if its possible then game on! WOOOO!
