raysmithweb
- Joined
- Apr 29, 2009
- Messages
- 6
- Reaction score
- 0
Team, my amp has two different types of noise, most noticeable on the clean channel. It's similar to what's described with other 50-watt amps: a "floor" of white noise proportional to the amount of gain and a popping type of white noise I can only describe as bacon frying. (No jokes here, please). The frying sound is only when the strings are played, not constant.
Now, some have said check and replace the tubes while others have said "have the amp repaired." Can anyone chime in if you've had a previously noisy amp that's quiet now and what needed to be done? Which tube was bad? What repair needed to be made?
Thanks to all in advance.
Ray
Ray
