gezza
Hello Guys,
I just got the 5:25 today, still sounds awesome.
I am having problems with the effects loop. Looks like it runs in Series, not parallel.
I am using a Boss GT8 for effects, I run it using the 4CM. The GT8 controls the Volume, changes the channel, adds Wah, Distortions, not to mention thr many effects, Tuner.
When I use the clean channel and then add distortion, I can still hear the clean tone and well as the distortion. I am used to putting the knob on Wet, but there is no wet. So I assume that the amp can not run in parallel.
This doesn't seem to be a problem on the dirty Channel as adding a distortion boost seems to mix very well.
Any Ideas, how to solve my problem.
Thanks,
Gezza.
Thanks,
Gezza.
