Hi! I think something is wrong with the channel switching on my Express 5:25. The footswitch changes between channels while the channel switch on the front of the amp is set to channel 1. If set to channel 2, the footswitch has no effect, as expected. It also works correctly when the switch is set to FTSW. I measured the switch on the inside of the amp, and it seems to work fine.
But the footswitch should of course not change the channels when the channel switch is set to 1. Anyone else having this problem?
