Build short cable for footswitch.
Nubbs
I want to build a short foot switch cable that comes out of the amp about 9 inches and ends.
The reason is I don't want to carry it in the amp and I don't want to plug and unplug each time.
So can any one help with what the male and female 5 pin plugs are and where I can find.
I have given though to purchasing an extra foot switch cable from Mesa, but that seems like overkill.
I have looked on-line for a similar set of plugs, but have not had any luck finding the same as what is on the cable.
Any ideas where to look??
Nubbs
"everybody has ability, but pride in performance is what makes the difference"
I'm not 100% sure, but I believe it's a standard MIDI DIN cable. You can probably get any length from a music store in the keyboard department.
i get them from electronic supply stores, both local and online. They are usually standard 5pin DIN cables.
