Mesa Studio pre amp outputs question.
csgband
My Mesa Boogie studio pre and my quad seem to only send out signal from the recording outs, when I use the main out into the power amp I get no sound.
The recording out into the power amp gives me sound.
Any thoughts?
Thanks
Chris
Any thoughts? Yes.
Use the effects send as your output to your power amp in. It has less compression and more clarity when you bypass those nasty master volume knobs. If you are used to using effects in the loop, just go from the send to the effects and then to the power amp.
