I bought it used in the 1990s. It doesn't have reverb or EQ. I think it's a Mark II but I'm not sure. If it is a Mark II, I don't know if it's an A, B or C. I do note the heading over the Master 1 says "Gain Boost" as opposed to "Pull Deep", so I am leaning towards a A or B. It also does have the captions above the knobs so it probably isnt a Son of Boogie. I dont know where to look for the serial number. There is a sharpie note in the board that says: LJ 3/3/82
Per the photo, the front side has 7 knobs: Volume1, Treble, Bass, Middle, Master1, LeadDrive, LeadMaster with captions over 5 of them: PullBright on Volume1, PullShift on Treble, GainBoost on Master1, PullLead on LeadDrive, and PullBright on LeadMaster. The right side has 2 throw switches: standby/on, and power/on. The back side has a 3 position throw switch for Ground, a knob and plug for slave, a plug set for effects send/return, a Presence knob, no reverb, and three different plugs for speakers. It has a Celestion G12T-75 speaker.
Image links:
https://imgur.com/mlndv1a
https://imgur.com/8mWiavT
Image links:
