Mark I reissue combo owners
blue-moon
Quick question for those with a Mark I reissue combo. Does the chassis on your combos float a little in the cab. On my combo the chassis has some give. The screws on top of the cab are tight. Even so there is still some give from front to back if you press against the faceplate.
Normal?
Yes, the SUS-4 suspension mounting has the amp chassis connected to the plastic/rubber-ish pieces, which allow a little movement in all directions.
