Les Paul -> Mesa Boogie MKIII -> Cabclone -> Focusrite
klauscanth
Post by klauscanth » Tue Jan 08, 2019 5:37 am
Hello all,
been experimenting silent recording with MKIII and Cabclone, in particular trying to get a CLEAN sound. I do NOT connect the Speaker Thru.
With single coils the sound is decent and can live with it. The sound is ok as long as the Vol 1 on MKIII is not past 5 and the Cabclone input setting is a notch above the minimum setting.
But if I use a Les Paul there is simply no sweet spot - even the lowest input settings on Cabclone as well as Focusrite recording preamp produce a slightly distorted sound.
The YouTube videos I have seen are million miles from the truth and I have a sneaking suspicion they are a mix of Cabclone and mic'd cabinet.
Anyone else ran into this, please? Any ideas how to deal with this?
with best regards, Klaus
klauscanth
Re: Les Paul -> Mesa Boogie MKIII -> Cabclone -> Focusrite
Post by klauscanth » Wed Jan 09, 2019 5:42 am
Did more experimenting and this is what I found:
In the case of Les Paul or any guitar with higher power pick-ups the volume of the amp (Vol 1) has to be REALLY low, about 2-3 max. Also, the DI level of Cabclone has to be just a notch above the minimum setting. Then, the pre-amp before DAW can be in fairly noonish settings.
I have only tried so-far with 16 W setting in Simul-Class - will test the 60 W setting and report back.
BR, Klaus
klauscanth
Post by klauscanth » Thu Jan 10, 2019 2:22 pm
Ok, I think I got it now:
- The key is putting a clean boost before input and keeping the Vol 1 to 2-3.
I used Boss LS-2 with 3-4 dB of gain. That rounds up the sound very nicely and does not distort the signal at the DAW.
BR, Klaus
