Mark IV channel switching question?
el34sg
Is there any way to switch channels on a Mk IV
without using the monster stock foot pedal?
Like the old school channel switching on a Mark II or III?
I'm looking to use the Lead channel and switch to R2.
Not channel one. Just channels 2 & 3.
You will need to leave the selector knob set to FT.SW. If you set it to this with no switches connected it should default to the Lead channel+EQ. If you plug in your tip to ground footswitch to the Rhythm 1 channel external switch you can jump between Lead and Rhythm 1. If you plug in your tip to ground footswitch to the Rhythm 2 external switch you can jump between Lead and Rhythm 2.
But EQ will always be on in the lead channel doing this
Thanks for the info, that's exactly what I was hoping for.
