MKIIc+ Tubes
Henz
MKIIc+ Tubes
Post by Henz » Mon Oct 30, 2017 10:48 pm
Greetings,..... EL34's in the outer sockets? Yay or nay? Thanks, James
MKIIC+
2:90
4x12 Recto Cab w/ Eminence and V30's
Home made 2x12 half open cab w/ Eminence and V30's
Rocktron Patchmate, Rocktron Intellifex, TS10 Tubescreamer
xdg999
Re: MKIIc+ Tubes
Post by xdg999 » Tue Oct 31, 2017 8:41 am
I had EL34’s in my DR and DRG but now I prefer Sovtek 5881’s with nos Chinese 12ax7’s. The 5881’s tame some of the brightness.
Mark IIc+ x 12, Mark III+ x 4, Mark V 25, 1994 Dual Rec Rev G x 2, Mini Rec, Studio Preamp, 50/50, D-180.
JOEY B.
Re: MKIIc+ Tubes
Post by JOEY B. » Thu Nov 02, 2017 10:30 pm
MESA branded Sylvania STR-416's are the way to go. Yes they are expensive and hard to find, but WELL worth it. Nothing compares in my opinion. I have a pair of Phillips 7581A's that do the job nicely, as well.
"One of these days, I'm gonna change my evil ways....... one of these days.
Henz
Re: MKIIc+ Tubes
Post by Henz » Fri Nov 03, 2017 10:07 pm
Thanx for the replies.... I purchased 2 EL34's to try, first to try in my 2:90 based on a u tube demo, but when i got em , i put them in C+. Since the head is my starting point. After a few days, i put the original tubes back in head ( which are 415's... very old ) They seem to be the most reliable. I'm a picky sob, im always doin this , that and the other. Even tho the 415's are 20 + yrs. old, shud I worry? Peace to everyone, James
MKIIC+
2:90
tony777
Re: MKIIc+ Tubes
Post by tony777 » Sun Nov 05, 2017 4:11 pm
Henz wrote:Even tho the 415's are 20 + yrs. old, shud I worry? Peace to everyone, James
As long as the 415 works, age doesn't matter, they're probably better than anything you can buy, and as Joey says as well. the 416 is also the best EL34 in my experience. Other tubes just doesn't come close.
http://tonykareid.com
Mark IIC+ SGX, DRGX x2
Mark III black dot DRGX
Mark IV A DRGX
Mark V:25
Dual Rectifier Rev G, Recto preamp
Cabclone
Mesa amp switcher
4x12 Recto standard
1x12 Thiele cab.
Tons of Ibbies, what a habit.
Henz
Re: MKIIc+ Tubes
Post by Henz » Sun Nov 05, 2017 11:14 pm
Thanx for the reply. Yep , i will. The 415 s have always been there, reliable for me. Blessings, James
MKIIC+
2:90
gts
Location: Looking over the shoulder of the guy who lost his apples - not that he really ever had any to lose.
Re: MKIIc+ Tubes
Post by gts » Mon Nov 13, 2017 2:32 pm
the Mesa STR-416 was made by Sylvania (as were the 415's).
That said if you can find some old Sylvania EL-34's in the correct bias range get them as they are the same tube.
The beauty of the 416's is they give you the chime of an EL34 but seem to have the fullness and bottom end of the STR-415's (aka 6L6's).
They are simply amazing tubes!
After getting my first pair I was so stunned by how the C+ sounded I played through it using only Class-A for months.
I still love the way it sounds in Class-A with 416's/ Sylvania El-34's!
Henz
Re: MKIIc+ Tubes
Post by Henz » Mon Nov 13, 2017 10:55 pm
Thanx for the reply. Are the EL34( 416's)( if i am understanding this correctly, the 416's are EL34's?) still on the market? Man, that sounds like thats what I need. I also usually only play in class A. Blessings to all, James
MKIIC+
2:90
gts
Re: MKIIc+ Tubes
Post by gts » Tue Nov 14, 2017 7:11 pm
Henz wrote:Are the EL34( 416's)( if i am understanding this correctly, the 416's are EL34's?) still on the market?
Yes the Mesa StR-416's are relabeled Sylvania EL-34's. Same tune different label.
They haven't been made for years.
The only way to get them is to find and buy some used ones or find/ buy New Old Stock (NOS) tubes.
These are long lasting tubes (10,000 hour tube) so buying used shouldn't be of concerns.
Do your homework, ask the seller for whatever info they on on the tubes and you should be fine with a used pair.
I have two pair of NOS and they cost a pretty penny. :shock:
But those in my C+'s were bought used and have been going strong for a few years now.
Henz
Re: MKIIc+ Tubes
Post by Henz » Tue Nov 14, 2017 11:28 pm
Thanx! If i find some , I am on it! Blessings, James
MKIIC+
2:90
