Wiring Mono 80's Cab Stereo?
viendette
So I'm rewiring my 80's Mono cab (It has one Jack output) to Stereo. I bought the jackplate from Mesa
Anyone have a wiring diagram so I don't screw this up?
Is this the correct wiring schematic for stereo?
I also found this one:
They're both series/parallel so is that the correct wiring to achieve stereo wiring? As you can see this is my first go at this. All speakers are 8ohms
I'm not sure those diagrams are right.
Check out mono/stereo 4x12 diagrams https://www.google.co.uk/search?q=stereo+wire+a+4x12+cab&safe=strict&client=safari&hl=en-gb&prmd=svin&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi545-tsuDSAhVpI8AKHe_XDDgQ_AUICSgD&biw=1024&bih=672#imgrc=_
You will likely need to use switched jacks to allow mono or stereo operation.
It's all good I figured it out. All is fine.
