It is currently Wed May 23, 2018 8:06 am
Post new topic Reply to topic  [ 12 posts ]
PostPosted: Fri Dec 02, 2016 3:46 pm
Does the black Mesa Mark III footwswitch switch between the RII/Lead channel or the clean/Lead channel? I want to use this switch to make the amp a 2 channel amp by switching from clean/lead. Also can I use a regular guitar cable to hook this switch up? Thanks.
PostPosted: Sat Dec 03, 2016 8:07 am
Yes to the guitar cable question, use it to plug the black footswitch into the footswitch jack under the guitar input jack on the front of the amp. Make sure both the rhythm 2 and lead knobs that pull to activate without the footswitch are pushed in. The amp should be in rhythm 1 ( clean channel) when the red light on the footswitch is lit and lead mode when you stomp it and the red light goes off. Rhythm 2 is a separate footswitch that plugs into the back of the amp. Hope this helps.
PostPosted: Sat Dec 03, 2016 6:56 pm
Thanks for the reply. I just bought an original 80's black footswitch. I had a previous problem with another footswitch I bought. It was an aftermarket switch that didn't work. Now that I bought the original I hope I'll be good. It's a black stripe and the best amp I've ever owned.
PostPosted: Sat Dec 03, 2016 11:55 pm
Yeah boogies got a lot of mojo. Let us know how you make out hopefully THIS switch will do the trick, it should if all is working correctly , If not someone on the board should be able to help you out. Alot of knowledgeable Mark lll owners and non owners here. I'm not one, knowledgeable about trouble shooting that is but many are. Hopefully the new switch
works out for you.
PostPosted: Wed Dec 07, 2016 7:52 pm
switch isn't working. I used a guitar cable to plug the switch into the amp under the "footswitch" input below the guitar input. I am not sure what is going on and why my amp won't take a footswitch. the light won't come on in that position, but if I plug it into the back of the amp under the "R2 switch", the light comes on... maybe I bought another broken switch.
PostPosted: Mon Dec 12, 2016 4:29 pm
Just a long shot here from something that happened to me. If your footswitch has an LED and it doesn't have a dropping resistor in line with it the light will come on but it will not switch the channels.
I know the is a footswitch schematic around the forums here if you need.
(edit) Here is the schematic viewtopic.php?f=6&t=65512
Just a thought. :mrgreen:
'58 VOS Gibson Les Paul || 1984 Custom Stratocaster || 2014 Gibson Firebird
Vai Legacy 1 Head || Mesa 2x12 Cab || Modded Blues Jr || Boogie Mk III ||
TC electronic Delay/Reverb || Plimsoul - Xotic Wah - EP booster - CS Deja Vibe
PostPosted: Tue Dec 20, 2016 11:22 am
there's a resister here. Everything looks good inside... the black box (I think it's a capacitor) inside looks a little aged
PostPosted: Tue Dec 20, 2016 11:26 am
maybe I can replace the switch part?
PostPosted: Tue Feb 07, 2017 12:53 pm
Worse case, old MkIII footswitches can be found on ebay, along with newly made clones that do the job.
Quad Preamp/2:90
MkIII+ Simul-Class & MkIVb
Mark 4x12 Stack
Charvel 650 Custom/EMG85/SLV/SLV+SPC
Charvel San Dimas I Koa USA
Jackson Soloist Pro MIJ
B.C. Rich Eagle Evo2/Air Norton
ESP Eclipse EMG 81/60
Ibanez UV7BK
Charvel 475 Exotic
Fender Tele USA
PostPosted: Tue Feb 07, 2017 1:51 pm
They're also available from our online store: http://mesa.stores.yahoo.net/hrtmkftsw.html
PostPosted: Wed Mar 22, 2017 6:50 am
Does anyone have a picture of the inside of the other Mark III footswitches (the Rhythm 2 footswitch and the EQ/REV footswitch)? I've attempted to build an EQ/Reverb footswitch that has indicator lights, but it's not working quite right. I know there isn't any power going to this switch to illuminate either LED indicator, but I installed a 9v battery, and it won't even engage either EQ or REV, even without LEDs.
Mark III Coliseum KDRG | Mark III+ Coliseum KDRG | Mark III DRG | Mark IV (Head) | Mark IV (Combo) | Dual Rectifier Revision D | Dual Rectifier Revision G
PostPosted: Thu Mar 23, 2017 5:49 am
The Boss FS6 dual pedal will switch R1/R2 and Lead in one.
I'm using one now with my Purple Stripe MKIII
With a stereo cable you can also switch reverb and EQ too.
Best thing is you can slot two FS6 pedals together to make a strip of four
Users browsing this forum: No registered users and 6 guests
