It is currently Fri May 25, 2018 9:00 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Mon Jun 20, 2016 10:14 am
I picked up this beauty for $700 and it has to be one of if not THE best sounding amp I've ever heard. The only thing is needed was an eq so, I picked up an MXR 10 Band eq in a trade. I am BLOWN away!
Would any of you like to share your thoughts or favorite settings on your Mark iii?
JP-2C
1985 Mark iii Simul Class Black Dot w/Red Stripe upgrade
1987 Mark iii Coliseum Purple Stripe
1987 Red Stripe Combo
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Tue Jun 21, 2016 8:36 am
My favorite setting for today is Volume one @ 8.5, treble @ 8, bass @ 1.5 pulled, mid @7, master 1.5 pulled, LD @ 5.5, LM @8, presence @ 7. MetalRock tone. Tomorrow might be different with the LD higher, Channel one lower. I always seem to adjust the GEQ every time I play, from a mild V to an M to a deep V for a Marshall/Fender tone. That's where you get the amp's feel from. These amps are organic, not bionic, and sound different everyday, they're alive inside, either that or atmospheric conditions affect it more than other amps. Also the tubes you use will matter in tone timber and how the sound jumps out. The right tube in V1, they all like a particular one, and the amp will leave a grin on your face you can't wipe off! 8) Oh yeah, I almost forgot - the amp needs to warm up for at least 20 minutes before it starts to thicken up. After an hour or two it'll ooze with tone. I was just messing with my amp and already the settings are a little different because I changed the pick up in my guitar.
JP2C, Mark llC++, Mark IV-A, Mark IV-B.
PostPosted: Tue Jun 21, 2016 2:19 pm
You ain't kidding! This amp is organic and I ALREADY can't get the smile off of my face. I own 2 Tremoverb 2x12 Combos a 94 and a 98 and I own a 98 Dual Rec Solo head that I run through an Avatar Cab with V30 Hellatones. And I THOUGHT I knew what I wanted UNTIL I got this little power house. My favorite settings in this place are: Volume 6.5, Treb 7, Bass 2, Mid 7, Master 3 (Pulled), Lead Drive 6.5, Lead Master 3.5
But it changes all the time AND for whatever reason I LOVE it. Also, I am now running an MXR 10 Band EQ in the FX Loop and MY GOD what a difference. This thing just CAME ALIVE!!
JP-2C
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Thu Jun 23, 2016 10:16 pm
Congrats on your new amp! I've owned lots of Mesa amp (Rectos, Marks, Roadking, F-50...) However, the Mark III puts a smile on my face every time too. Enjoy your amp.
Mark V head
Mark V 25 head
Mark " III +" (originally green stripe) Simul-Class, short head
Dual Rec head (multi watt)
Mini-Rec
Cabs: 4x12 Recto traditional, 2x12 Recto (horizontal), 1x12 Wide Body (closed), 1x12 Wide Body (open back)
PostPosted: Fri Jun 24, 2016 10:04 am
Congratulations on the new amp! I love my Mark III too, so many tones that you can get out of it.
PostPosted: Tue Jul 05, 2016 9:22 pm
Congrats ! I have a Mark III no stripe here. Try these settings as a starting point. You will find some thing that needs to tweak a bit to fit your tone. Its a bit fuzzy when your low volume in the bedroom or something but, open it up to 1.5 - 2.5 and it has exactly what works for me.I ride my volume on the guitar a lot of tone changes.
Good luck, you will love that amp!
My Mark III amp.
'58 VOS Gibson Les Paul || 1984 Custom Stratocaster || 2014 Gibson Firebird
Vai Legacy 1 Head || Mesa 2x12 Cab || Modded Blues Jr || Boogie Mk III ||
TC electronic Delay/Reverb || Plimsoul - Xotic Wah - EP booster - CS Deja Vibe
PostPosted: Mon Jul 25, 2016 11:43 am
For whatever reason I am just seeing this post. Thank you so much! That is a great graphic and settings!
JP-2C
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Wed Jul 27, 2016 4:14 am
I love my Red Stripe, it's a Marshall killer... once it's dialed in. I can get almost perfectly John Sykes' tone from Whitesnake's 1987 album. He used a couple Red Stripe Coli's for that album, same preamp with two extra power tubes. Settings I have so far are Volume 9, Treble 9, Bass 1, Middle 5, Lead Drive 7.5. Master and Lead Master set as high as you wanna go. I have the GEQ set in a V pattern. I throw a light overdrive and compressor (on a low setting, unless you like NOISE) in front and a mild chorus in the loop (I found it opens up the amp even more than just the GEQ alone). Perfect Whitesnake/Pyromania-era Def Leppard. I'm still tweaking though, after having the amp for almost a year.
Seriously, enjoy this thing. If you're patient in dialing it in to your liking, it'll blow most things out of the water.
Mark IIC SRG
Mark IIC+ DRG
Mark III Red Stripe Long Chassis
RA 100 Custom
Subway Blues
PostPosted: Sun Oct 02, 2016 11:40 pm
Timmy,
That was an awesome reply! And every single thing you said was on the money! I have sine bought abother one ( a black dot with the red stripe upgrade & it he the GEQ) AND A Mark V and the red stripe is still my favorite!
JP-2C
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Thu Oct 06, 2016 3:09 pm
Congrats on ur getting one of the most underrated amps ever! 700 USD is a real bargain even if it comes with no eq.
MESA BOOGIE MARK III BLUE STRIPE proud owner
https://www.youtube.com/watch?v=qqZz5rHHIIk
https://www.youtube.com/watch?v=VBXj8AJ108Y
https://www.youtube.com/watch?v=1gejXLj8W-Q
https://www.youtube.com/watch?v=6Eptmr_XaRQ
PostPosted: Fri Oct 07, 2016 11:22 pm
Congrats on the best Boogie ever made!
Keep the presence down with or without the eq.
I can get unbelievable warm tones out of my Green & Red Stripe Mark III's.
As long as the Presence is below 2.
I love how Mesa Boogies self proclaimed biggest Mark series failure, the Mark III is
my all time favorite Amp. Best midrange without question..
The money I could have saved if I had bought one 25 years ago..
PostPosted: Tue Oct 11, 2016 8:17 am
I love Mark 3s and there are so many different ways they sound good. Maybe a less obvious one: use the lead channel but turn the lead gain down as low as you can get it before the signal starts to fade out (I wanna say this is usually like 1-2 on the dial, depending on your guitar). Then roll the presence down. Great smooth overdrive and compression.
PostPosted: Thu Oct 13, 2016 7:33 pm
Congrats, and welcome to the III club! Ever time I play the blue stripe it makes me happy! The amp is stock, no mods, just guitar to amp. Oh my settings are:
9.5 Volume 1
7 Treble pulled
1 Bass
4 Middle
8 Lead Drive
5.5 Lead Master
0 Reverb
1.5 Presence
1985 Mark IIC++
1989 Mark III Blue Combo
1991 Mark IV Short Head
PostPosted: Mon Oct 31, 2016 3:43 pm
thank you all for all of your comments! They helped tremendously! Especially you, themisfit138, HOW did you get that pic like that? That's boss!
That amp SO inspired me that, I now own a Mark V, a JP-2c+, AND I got another Red Stripe but this on is the Simulclass and has the GEQ and it was originally a Black Stripe that was upgraded to a Red Stripe. That one is amazing as well!!
I can't believe it took 35 years of playing to find out that the tone I was looking for was in a Mark series amp (Specifically the JP-2C+)
JP-2C
Mark IVb
Rocket 4Forty
JP2C (#2)
PostPosted: Tue Nov 01, 2016 6:52 pm
I got it off of here a a few years ago,in one of the Mark III threads. Here is the link http://www.chain-metal.nl/mark3/
Also, I use a foot switch when I play the Mark and just didn't list the lead channel knob as pulled.
1985 Mark IIC++
Users browsing this forum: Google [Bot], Google Adsense [Bot], Tiki295 and 3 guests
