FCB1010 not switching Mark IV channels properly
godisme
Hey, the problem is that when I press the button on the FCB1010 it switches the channel on MarkIV but only when I keep it pressed down. When I release it, it goes back to the previous channel. So the FCB does not keep the switch on afer depressing the button. It's not normal, is it? Is there something I need to reset on the FCB1010?
I don't know that the Mark IV is actually compatible with the FCB1010 but it sounds like you've got it set to pulse instead of latch, that might solve your problem if theres a way to change that.
Ok I got it to work by changing some settings on the FCB1010. But there is a nasty sound every time I change channels so I won't use it. I ready somewhere that it's becasue of ungrounded circuits on the FCB1010 or something. I'll probably replace the FCB1010 and ghet something that can control both channels on MarkIV and the TC Electronic NOVA System.
