HelpingFriendly
- Joined
- Mar 9, 2014
- Messages
- 69
- Reaction score
- 0
Hey phreinds. So I just brought my purple stripe to my local tech for some things done and a once over. I asked him to install a bias pot, change the filter caps and depending on how it checks out maybe a triode/pentode switch. So long story short he took 2 hrs bench time to tell me there was a resistor that was burnt and he replaced as well as a wrong cap value which was causing havoc. So he then proceeded to do the bias pot and triode/pentode switch and now the bill is $392!!
The worst part of all this is the one thing I wanted done most was the filter caps. I suspect they are the original caps and are pushing 30 years. He is an old school guy who has been working on tube amps for 50 years and is in the "if it aint broke don't fix it" school. Which I totally get but if a cap is almost 30 years old I would assume that if I put new quality ones in I would notice some improvement in tone of at least in response? This guy told me the caps were fine and not to change them. The thing that really kinda bothered me is before I even brought my amp there he was leaning towards not doing them. Saying "we'll see when it gets here BUT these caps hardly fail unless the amp is not played for some time." Which yes is true but it also wouldn't hurt to update them either. Is it hard to do or something? Is that why he was so anti-recap? I know the 4 long 220uf caps are in a detachable pcb so that should be an easy install. But does anyone know if the other 3 30uf caps have to have the whole board flipped to install?
Since I can't afford to have a tech do it now I want to do myself. I know how to discharge the caps and understand all the safety precautions. I have done plenty of mods before and can solder. Does anyone have any tips on recaping a Mark III? Is there a way I don't have to flip the board for the 3 30uf's on the pre board?
