midi help with mark 3
shush
Post by shush » Sun Mar 04, 2012 6:14 am
Hi Guys,
I need some expert advice :)
I have a mark 3 combo and a tc electronic g major, im wondering is it possible to control the amps channel changes with patch changes on the g major via a midi foot controller ?
Id like to be able to do this but dont know how :cry:
Any advice would be most welcome
Thanks Guys
Sean
rocknroll9225
Re: midi help with mark 3
Post by rocknroll9225 » Sun Mar 04, 2012 6:25 am
I could be wrong but I believe the G major has one relay switch built in, which would only be able to control one function. So you'll need something with MIDI-controllable relay switches, like a GCX (http://www.musiciansfriend.com/guitars/ ... o-switcher) or a RJM Amp Gizmo (http://www.sweetwater.com/store/detail/AmpGizmo).
And if you want advice for a specific make or model, I am a strong supporter of RJM :D
EDIT: I just looked it up, apparently it has 2 relays, so you could switch the channels but not the EQ and reverb. And TC units' switching relays have a reputation of not working well with most mesas, since they require isolated ground connections, which the TC's don't do, apparently. I'm not sure if that applies to older mesas, though, or just the newer ones.
My Rig:
Furman P-1800 AR
Line 6 Relay G90
Fractal Axe-Fx II
RJM RG-16
iSP Decimator ProRack G
Dunlop DCR-2SR Crybaby
Mesa/Boogie Mark V
Mesa/Boogie Dual Rectifier Multi-Watt (pre-500 mod)
Roadster 2x12 cab
https://www.facebook.com/BuriedElectric
zebpedersen
Post by zebpedersen » Sun Mar 04, 2012 7:46 am
I see you're in Yorkshire – the only UK reseller of RJM gear (if that's the route you want to take) is Tone World (http://www.toneworld.co.uk/rjm-m11).
I'm looking into getting the RG16 at the moment, which does FX switching as well as channel switching, but the figures stand true for all RJM gear purchased in the UK - it's really expensive!
For example, for the RG16, the US MSRP is $750 and street price is $650, whereas you're paying £725 (>$1100) in the UK for the same unit. As they all seem to run off a wall wart, you might be better off ordering one from the States, in which case even with a conservative shipping estimate of $75, you'll still be paying about £450 - nearly 300 quid less than the UK street price.
If you're just doing channel switching, maybe you want to look into the Mini Amp Gizmo, which is £189 (and might be cheaper still if you order from abroad).
Mark I HRGX 15"
Mark IIC+ DRG
mboogman
Post by mboogman » Mon Mar 05, 2012 9:41 am
The G Major has a TRS (Tip, Ring, Sleeve) relay jack on it. I use my G Major to control my MKIII with patch changes just like you describe. You can actually pick two functions to control with the G Major. You will need a TRS to Dual TS "Y" cable to make that work, like a standard Insert cable. When you set up your preset on the GM, simply set the relay states (open or closed) and save the preset. Works like a charm. You can even set up a standard momentary style switch to control one of those functions too, and not loose the ability to have the recall with your presets.
Mesa Boogie Studio Preamp w/MKIIc+ mod
Egnater M4 w/ Xman, EG5, VX, EG3 mods
VHT 2:90:2 power
Lexicon MPX-G2
TC Electronic GMajor
Digitech IPS33b
Voodoo Labs GCX/Ground Control Pro
