strange thing happened to my mark IV tonight:freaked me out
kmanick
BOSTON
I was just jamming out a little on it and all of a sudden all of the gain disappeared from the lead channel.
I still had my volume but it was completely clean.
I switched over to R1.....fine
R2.................fine
back to lead.........still clean.
I turned it off and went upstairs. came back down 10 minutes later turned it on and it was working fine again,
but the lead channel sounded a little "thin".
I looked at the tubes all seemed ok, I schecked them all to make sure they were all seated properly.........OK.
any idea what's going on here?
You might want to first quickly check the preamp tubes. I had the same thing happen to my IV, loss of gain and distortion on the lead channel, but R1 and R2 were fine. Found a preamp tube that looked fine but must have been slowly failing and replaced it. Sounds great now. Good luck.
ok thanks guys I will do that tonight wehn I get home from work, any idea which tube is 'assigned" to the lead channel (if there is one)?
I noticed when I looked into the back of it last night that 2 of the preamp tubes have sleeves on them
is there a tube layout for the IV "A" anywhere?
V3(first lead stage) & V4 (second lead stage) preamp slots.
Manual (page 21): http://www.mesaboogie.com/manuals/Mark 4.pdf
~Nep~
muchos Gracias! :D
~Nep~
