I just found this forum, and I hope this is posted on the right place.
I used to be the very happy owner of a MarkIII top. I still have the amp but I am not happy.
It is of the first year MarkIII’s that were made, or so I am told. The local Boogie guru told me that this was easy seen by some letters that are uses on the amp- -Letracet ore something.. 1982 I believe he said.. It’s a long time ago.
Anyway. I started to get a bit of noise, as I have had before, and decided to get it checked and get new tubes. It has been just like this before, and after a checkup it has always come back as the same wonderful amp.
This time I found out there was a problem with getting tubes. The ones I used was not available anymore. The right tubes were not possible to get anymore, but the TADtubes should be fine I was told. I have now tried some different tubes and.. well the noise is gone, and so are the magic. It sounds just like any other sh%&tamp..
The clean-chanel is not as bad as the lead-chanel witch I cannot describe here without breaking the forum rules..
Note: The amp-guy knows his work, so it’s not at Bias thing or something like that. He says there is nothing wrong with the amp, so my guess is that it needs the “right” tubes(?)
Maybe some of you have experience, and can help me out?
