Metallica tones HELP!
MetalMesahead
Hi i new to the board.
I have a mesaboogie MarkIV shorthead. i have messed around with it but i just can seem to get a real GOOD Master Of Puppets tone. Any buddy got some ideas???
thanks :twisted:
Try the classic V setting on the Lead Channel for starters.
Full power/ Triode/ Simulclass... Crank your amp to 8 on the master.
8 on the preamp.
8 on Gain
8 on Drive
Set eq knobs to desired tone
Get (4) Oversized recto cabs.
Use an EMG 81 and 85 in a high end ESP...
umm, is there anything im missing? ? ?
There must be a wormhole between HCAF and here!
At any rate Grandor is pretty close.
Try this...
Gain 7-8, Drive 8, Bass 5.5, Mid 4.5, Treb 5, Pres to taste, "V" the EQ, Preamp at least half way, Master right at the threshold where your neighbors will call the cops. The louder you turn it up, the closer you're going to get. Flatten out the "V" a bit as you turn up.
