Mark III simull class head how do i know which version is?
mxr2000
Post by mxr2000 » Sun Jul 27, 2008 12:45 pm
just found a mark III simul class 100 watts sounds great but i would like to know Which version is and how to date it? its a small black head s/n 22999
Psyence88
Post by Psyence88 » Sun Jul 27, 2008 2:44 pm
It should have a color stripe above the power cord and it's dated right on the chassis.
http://homepage.mac.com/mesaboogie/dot.html
Read about stripe versions here!
Deus Le Volt!
'86 Mesa Boogie Mark III fully loaded combo w/ V30
'07 Ibanez S2170FW
'08 Ibanez JS1200CA
mxr2000
Post by mxr2000 » Sun Jul 27, 2008 6:32 pm
according to this info, mine is blue stripe but i can't find the date of the amp yet
Mark Fore
Post by Mark Fore » Sun Jul 27, 2008 7:21 pm
To find the date you will need to open her up and remove the chassis. The date should be written inside like the picture below of my Mark III:
Any Mark Available
mesaboogie6L6
Post by mesaboogie6L6 » Sun Jul 27, 2008 7:45 pm
If you look under the chassis by the first preamp tube (V1) there might be a date, mine is marked 10/90 in red sharpie.
90' Mark III Coliseum blue stripe
95 Triple RevG
96' Triple RevF (2)
04' Recto 4x12
07' Recto 4x12-EVM12L's
09' Mills (2)-4X12-V30
96' Explorer
03' Faded V
13' Government V
phyrexia
Post by phyrexia » Sun Jul 27, 2008 9:37 pm
FYI if it's simul class it's not 100w.
“A journey of a thousand miles must begin with a single step." Lao Tzu
IXIStreakIXI
Post by IXIStreakIXI » Sun Jul 27, 2008 11:21 pm
Yes it is. My Simul-class is 60/100.
MrMarkIII
Post by MrMarkIII » Mon Jul 28, 2008 1:46 am
IXIStreakIXI wrote:Yes it is. My Simul-class is 60/100.
Sorry, no.
The "Simul-Class/Class A" switches on heads are often mis-labeled "Half/Full Power".
Simul-Class is 75 watts Simul (all four tubes), 15 watts Class A (outside pair). The outside pair (ONLY) may be EL-34s or 6L6s. Green stripes go up to 85/25 as the outside pair is wired pentode.
There is no such animal as a 60/100 Simul-Class. It's either 60/100 -OR- Simul-Class.
Never both. Never. NEV-ER.
You can't run EL-34s in the outside pair of a 60/100. It's got to be all 6L6s.
mxr2000
Post by mxr2000 » Mon Jul 28, 2008 12:28 pm
mine says on the back simull class and the half and full power switch is the front face plate and the reverb control is on the front face plate too
MrMarkIII
Post by MrMarkIII » Mon Jul 28, 2008 1:16 pm
mxr2000 wrote:mine says on the back simull class and the half and full power switch is the front face plate and the reverb control is on the front face plate too
You have a "long" head. "Short" heads are 18.5 inches wide and the reverb knob's on the back like the combo. Eight knobs on the front = "long" head.
The "Simul-Class/Class A" switches on heads are often mis-labeled "Half/Full Power". This switch actually means:
Simul-Class is 75 watts Simul (all four tubes, "Full Power"), 15 watts Class A (outside pair of power tubes, "Half-Power"). The outside pair of power tubes (ONLY) may be EL-34s or 6L6s.
mincy
Post by mincy » Mon Jul 28, 2008 1:20 pm
Mine is the same. Simul class label on the back, half/full switch and reverb on the front. It's a red stripe head.
Gibson Les Paul Custom
PRS Custom 24 Artist Series
Mesa/Boogie Mark III Simul-Class Red Stripe Head
Diezel Herbert
'72 Fender Silverface Super Reverb
mxr2000
Post by mxr2000 » Tue Jul 29, 2008 3:16 pm
Hey thats how mine looks too. but sure with the blue stripe :D
mxr2000
Post by mxr2000 » Tue Jul 29, 2008 3:20 pm
Man this most be the loudest 15 watts on earth.. :lol:
goodwill559
Post by goodwill559 » Tue Jul 29, 2008 3:39 pm
Should be 25 watts with the EL's wired pentode, IIRC.
mxr2000
Post by mxr2000 » Tue Jul 29, 2008 3:47 pm
goodwill559 wrote:Should be 25 watts with the EL's wired pentode, IIRC.
thanks for the tip :D
