Dual Caliber 5 acting strange
Posted: Sat Sep 05, 2015 1:21 pm
by Reaper1984
I've googled but can't find a description for this.
At first i thought this was an issue with the GEQ but it wasn't. What happens is on the lead channel alone and lead + GEQ, The bass in the tone just drops out, or the highs drops out and the bass is left..then i can twist a little on the knobs or GEQ, and it goes back to normal, or just play on and for a minute or so it goes back to normal.
I've changed the power tubes, but not the preamp ones, but when i look in the manual, it sounds like you never "really" need to change the preamp tubes?!. I don't know how old my amp is, but he said he never changed the tubes, so they were probably originals. What preamp tubes should i get if i need new ones? I'm just using the amp for metal and some funky rhytms on the clean channel.
Re: Dual Caliber 5 acting strange
Posted: Sun Sep 06, 2015 2:19 pm
by Reaper1984
anyone?
Posted: Mon Sep 07, 2015 10:50 am
by macdaddyof9
try spraying out the pots with contact cleaner. I have had similar problems and was gonna replace some pots when I tried this and it worked great. I use DeoxIT.
Posted: Wed Sep 16, 2015 4:58 am
by Reaper1984
thanks for the tip, but i guess that's not it i googled, and i have no problems with cracking/noise/scratching etc.
It happens without tweaking any knobs! :cry:
i havent flipped all preamptubes yet, only the one closest to the mesa boogie sign on the front cover, "the first preamp" i wonder if anyone knows (dont see anything about this in the manual), which preamp tube or tubes helps the lead/lead geq channel?
Posted: Wed Sep 16, 2015 11:36 am
by bendo
You may still need to clean your pots. Fizzling cracking isn't the only issue that can occur when the pots need cleaning.
If that does not fix it (it is your cheapest route) then replace the pre-amp tubes.
Anything outside of that will likely need a trip to an amp tech.
Posted: Thu Sep 17, 2015 6:46 am
by macdaddyof9
I forgot to mention that cleaning out the jacks is also very important. I think there may be some switches in the loop jacks that can cause issues. I spray then plug and unplug a patch cable and twist several times. I don't really know why but that has fixed a few strange problems too. Over all I've been lucky and not needed a single repair on this amp. Impressive for a 25 year old piece of gear.
Rock on
