DC5 has blown output transformer, need tech advice
DC-2, 3, 5, 10
50 Caliber
BobbyOrr
Post by BobbyOrr » Sat Dec 13, 2014 2:35 pm
I just bought this used DC5, played it at home for a week, no problems, took it to a gig and when I first plugged it in, there was a crackling noise and then smoke coming out the back with a bad smell. I think it's probably the output transformer, but there is no tech in my area that I can trust, so I'll need to send it somewhere. Should I send it directly to Mesa or does anyone have a good tech they can recommend?
zolimer
Re: DC5 has blown output transformer, need tech advice
Post by zolimer » Mon Jan 05, 2015 6:27 pm
send them an email. They will point you in the right direction.
Don
Post by Don » Mon Jan 05, 2015 10:36 pm
Did it blow a fuse? It could just be power tubes and screen grid resistors.
Old BF Shred
Post by Old BF Shred » Tue Jan 06, 2015 12:17 pm
Don wrote:Did it blow a fuse? It could just be power tubes and screen grid resistors.
+1!!
This is a common failure for tube amps. It is most likely a bad tube shorted and caused the grid resistors to burn up. Usually it will blow the fuse without harming the transformer (usually). If the fuse did not blow, I would check the fuse rating. For a 50 watt amp it should be (about) a 3 amp, slo-blo type fuse.
Since you did not specify your location, I don't know what tech to recommend.
Also, Mesa responds to phone calls more quickly than emails; I'd give them a call!
Good luck! :wink:
Stiletto Ace head
Triaxis/50-50
4x12 and 1x12 cabs
Studio Cal 22+
Various Hamer, G&L, Jackson
"Old rockers never die; we just start to smell that way...or is it the amp?"
BobbyOrr
Post by BobbyOrr » Tue Jan 06, 2015 7:13 pm
+1!!
Good luck! :wink:
Found a good tech, it turns out that it was a shorted tube and the grid resistors burned out, but it didn't blow the fuse. Thanks for the help.
Old BF Shred
Post by Old BF Shred » Tue Jan 06, 2015 11:21 pm
Very cool!
Now you'll have a nice amp with fresh tubes.
Enjoy! :D
Stiletto Ace head
Triaxis/50-50
4x12 and 1x12 cabs
Studio Cal 22+
