I purchased a used 50 Caliber + back in March and it had 3 standard JJ ECC83 preamp tubes, a JJ ECC81 in the fourth position and an Electro Harmonix 12AX7 in V2. The power tubes were Ruby 6L6GC's.
Although the amp sounded good, it was a little "buzzy" sounding and I kept the gain low, to keep the buzz down.
I just put a pair of JJ 6L6's in and moved the JJ ECC83 in V1 to replace the Electro Harmonix 12AX7 in V2. Then, I put a JJ Gold Pin ECC83 in V1. And WOW! The gain is so much smoother sounding. I was able to turn the gain up a couple notches and it still sounds smooth.
Has anyone else tried the Gold Pin preamp tubes from JJ? I wonder how much of the change in tone is from the new power tubes, the new preamp tube, or from getting rid of the 12AX7?
