DC5 newer version footswitch question
FLYING V 83
Is the 2-button footswitch for the newer DC5 for channel & EQ or reverb & EQ?
I've seen both versions aftermarket (Voodooman & Switchdoctor), so I'm confused.
If I get the channel/EQ one, do I use a TRS cable & plug in the front panel footswitch jack and set the rear switch to "eq assign" and get a single switch for the rear reverb jack?
Or... do I use the single channel switch it came with in front, and get the reverb/eq switch and use a TRS cable & plug into the reverb jack on the back?
Hope someone can clarify....
Original DC amplifiers have a two position toggle switch on the front panel that provides manual switching from Rhythm to Lead. These models also feature a five position rotary switch on the rear panel for manual EQ selection.
Later model DC's have a three positon toggle switch on the front panel which is labeled(top down): Rhythm - Lead - Lead/EQ. These models feature a two positon toggle switch on the rear panel for EQ channel assignment.
The 2 button FS is for Channel and EQ, seen here: http://mesa.stores.yahoo.net/fcdcn.html
The single button Reverb footswitch can seen here: http://mesa.stores.yahoo.net/fcr.html
I hope this helps!
Thanks AB, I know I have the 'later' model, just not sure which switch & where to plug 'em in!
(see my original post)
Thanks AB, that's what I needed to know!
I'll assume I need the TRS stereo cable for the front, and a standard mono cable for the reverb in back.
Perfect!
THIS is why I joined this board as soon as I got the DC5! :)
