Caliber .50 + ; Pots needed
stratele52
Quebec Province , Canada
I'm looking for 2 pots for Mesa Boogie Head , .50 caliber +
These pots are for Presence and for Reverb . Customer broke the shafts
Can't find these pots on the web. I just find one place in United State but they don't ship in Canada.
Can you help me ?
Thank's
amprepairparts.com/pots.htm : they don't ship
Here whats I need and thye have it ;
POT, MESA BOOGIE, 100K OHM LINEAR, (B100K), SOLDER LUGS, 24mm DIAMETER BODY, LONG "D" TYPE SHAFT, 3/8" BUSHING. Used in many earlier Mesa Boogie amps, especially their early combos. This pot has a plastic "D" shaped-shaft. Original Mesa Boogie part # 591050. DOES NOT INCLUDE NUT OR WASHER. IF NEW NUT IS NEEDED, ORDER THE JNUT-38 NUT FOUND IN THIS SECTION
Part #MB-591050
$5.95
POT, MESA BOOGIE, 250K OHM AUDIO, (A250K), SOLDER LUGS, 24mm DIAMETER BODY, LONG "D" TYPE SHAFT, 3/8" BUSHING. Used in many earlier Mesa Boogie amps, especially their early combos. This pot has a plastic "D" shaped-shaft. Original Mesa Boogie part # 591048. DOES NOT INCLUDE NUT OR WASHER. IF NEW NUT IS NEEDED, ORDER THE JNUT-38 NUT FOUND IN THIS SECTION
Part #MB-591048
$5.95
http://www.tubeampdoctor.com/en/shop_Potentiometer_Pots_with_solder_lugs/
lots of pots there!
You can order the parts directly from Mesa. Just contact Customer Service. http://www.mesaboogie.com/US/info.html
