Erotomaniac1928
- Joined
- Jan 13, 2009
- Messages
- 143
- Reaction score
- 0
Im having a bit of trouble getting a good leading tone out of this amp. Ive gotten a pretty good high gain rhythm though. Any suggestions?
Erotomaniac1928 said:The problem with the gt-6, is that when using the 4CM the "external" function is in the distortion/OD section (instead of the preamp section where it makes sense). because of that, I have no access to the gt's distortions when using the DC's preamp. I hope I dont have to get an external pedal just to add that extra "thickness" to the gain. I may just get a gt8 instead. That, or rack fx with a midi footcontroller.
madryan said:This may sound stupid but how loud are you turning up the amp. The DC's compress quite a bit when you get them up to band volumes and as such they're really smooth for that sort of thing. I generally dial in my rhythm sound without the EQ and then bump the mids with the EQ for a lead boost.
Remember, Tube amps like to be loud.
highwaynine said:If the GT-8 lets you do that *with* the 4CM, I'd say you're in great shape.
Monsta-Tone said:Believe it or not, the DC-3 has better cleans.
Enter your email address to join:
