No reverb on my 50. cal
JkP
In my 50 caliber I put in a new reverb tank, reverb transformer, driver tube, still no reverb. There is just a faint sound when I touch the springs with the volume turned up high. Any ideas or suggestions would be appreciated. Thanks.
Hmm? I had a similar, if not the same problem, with my DC-5. Try opening the reverb tank and check if the wires haven't come loose from the connections. That's what it was with mine. That and a dry soldering joint. Sounds odd though with it being a new tank. Worth a try though. Good luck!
