Mark III Simul Redplating on two adjacent power tubes sockets (6L6 and EL34)
Red3
Post by Red3 » Sat Nov 09, 2019 6:42 am
Mark III Red Stripe, Simulclass is redplating on two adjacent power tube sockets (6L6 and EL34). I've tried swopping out tubes same result. The plate current on these tubes runs very high (80ma). The other side (6L6, EL34) the bias is steady and in spec. Any thoughts would be great, thanks.
JD
Re: Mark III Simul Redplating on two adjacent power tubes sockets (6L6 and EL34)
Post by JD » Tue Nov 12, 2019 5:38 am
Check to see if C511 or C512 are not shorted
woodbutcher65
Post by woodbutcher65 » Fri Nov 29, 2019 12:20 am
JD probably hit it in one. If a coupling cap shorts (it'll be a .1 uF 600 volt orange drop) then the tubes on that side of the OT will lose bias and will red plate. It's recommend to replace both coupling caps as as pair.
Been there, done that.
Red3
Post by Red3 » Fri Dec 27, 2019 7:19 pm
Thanks guys, I'll get on to it.
