Original Mark II C+ vs. Mark II C Conversions, Any Differences?
'59fatburst
Post by '59fatburst » Sun May 26, 2019 9:44 am
I'm wondering if anyone out there has any experience playing both an original Boogie Mark IIC+ and a Mark IIC converted to "+" specs? It seems that a lot of the available amps right now are IIC conversions and I'd consider those over an original IIC+ if there was no discernable difference. Also, there seems to be a bit of a cost savings going with a conversion over an original, factory IIC+. Thanks!
jrb32
Re: Original Mark II C+ vs. Mark II C Conversions, Any Differences?
Post by jrb32 » Fri May 31, 2019 2:05 pm
Depends on the board. If the IIC has an SP11A or RP11A (from about September 83 onwards) then a converted IIC+ will be IDENTICAL to a factory IIC+ in every physical way. Seriously. 100%. No question.
If it has an SP10A or RP10A (the early IICs before this) then it will be identical from a circuit point of view but be DIFFERENT to a factory IIC+ physically.
You'd need internal pics to confirm this. But then it gets more complicated from a technical standpoint the ORIGINAL IIC+ (the one MB and DW modded) used an SP10A or RP10A board (99% confident on this) so go figure...
Both are killer amps. Worth the investment if the price is right.
For my ramblings:
viewtopic.php?f=27&t=18184&start=195#p522342
'59fatburst
Post by '59fatburst » Fri May 31, 2019 9:13 pm
Wow, thanks for that. I guess I need to do some more homework. I thought all 2C's were the same. I didn't know about the board differences.
JCB1980
Post by JCB1980 » Fri May 31, 2019 9:31 pm
Outside of the differences mentioned above involving the pcb, the differences are in the power transformer. Even a IIC with the RP11a board will most likely have a different pt, at least where the DRG and HRG are concerned. There may have been a couple IICs right at the end that got a 105 and a couple factory IIC+ that got the 100, but those are exceptions.
The PT is where people really get caught up in the whole Factory is better than upgrade debate. You can read the Guide for Dummies on here for the transformer breakdown.
Boogie Gear:
83 Mark IIc+ DRG (upgraded IIc I)
85 Mark IIc+ SG
91 Mark IVa
93 Dual Rectifier Rev F Blackface/Chrome Chassis
95 DC-5a
Thiele w/EVM12L
Halfback 2x12 w/MS12 and EVM12L
5 Band Graphic pedal
xdg999
Post by xdg999 » Fri May 31, 2019 9:41 pm
The difference is the power transformers and also if a Simul Class has the brightness reduced. A factory HR has punchier cleans and tighter overdrive. An early factory DR with the brightness reduced has sweeter cleans/leads and softer attack. My upgraded HR is somewhere in between and is one of my favorites. The Coliseum has the most low end and the leads are super creamy. A Simul with the brightness increased has very detailed cleans and a more aggressive lead tone. The most tone for the money would be a Studio Preamp with the 50/50 power amp. I asked Mike B. if he could do a c+ "lite" mod to my Studio Pre instead of a full blown c+ mod. He said he could change a couple caps to warm it up. It sounds really good with the 50/50 powering two vertical metal grill 2x12's. Another cost effective amp would be getting an early Mark III with the 105 transformer and sending it to Mike B. for the III+/R2 mod. I actually spend most of my time playing thru my Mark III+ DRG with the x101 transformer. Mike B. just finished working on another Mark III+ DRG with a 105 transformer. Someone had hacked up the circuit board so Mike put in a later Mark III board. He said R2 should have more push. I can wait to get it back.
c+: Factory HRx4,HRG,DRx2,DRGx2 Upgrades KARG,HR,HRGx2,DRG
III+: HRG/105,DRG/105x2,DRG/x101,SRG
Mark V 25
Studio Preamp - 50/50
D-180
1994 Dual Rec x2,Mini Rec
How many guitars and amps do you really need? :twisted:
