Safe to disconnect reverb tank from Mark IV?
wiiqwertyuiop
Post by wiiqwertyuiop » Thu Aug 23, 2018 5:03 pm
I never use the reverb on my Mark IV, is it safe to run the mark iv without the reverb tank attached?
Authorized Boogie
Re: Safe to disconnect reverb tank from Mark IV?
Post by Authorized Boogie » Thu Aug 23, 2018 5:16 pm
wiiqwertyuiop wrote:I never use the reverb on my Mark IV, is it safe to run the mark iv without the reverb tank attached?
Absolutely - no issue at all.
nor
Post by nor » Tue Feb 26, 2019 5:04 pm
My tech (Lowell Amps) recommends pulling the tube as well.
Authorized Boogie
Post by Authorized Boogie » Tue Feb 26, 2019 6:21 pm
If you did that, the amp would have no sound - V3 and V4 necessary. There is absolutely no need to remove the reverb driver/return tube when using the amp after disconnecting the reverb tank wires.
